Trying to prevent ZnCl2 to react with steel
Working on a battery with a steel casing.
Steel casing is lined with graphite paint but the zncl2 inside the battery still reacts with the steel.
Does Ag react with ZnCl2 ? is there a way to coat Pure graphite on steel (enough to prevent the reaction with ZnCl2)
I have tried to use 0.02mm pure graphite flake foil whoch seems to work but will be cost prohibitive in mass production.
RE: Trying to prevent ZnCl2 to react with steel
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Other chemistry batteries do not have the issue of zncl2 , in our research we are bound by zncl2 for other reasons.
Graphite does protect the steel but trying apply it to the inside of a can is still a challenge.
TTFN
Zinc acts as an anode in a conventional zinc-carbon battery and does not use a steel can for conductivity.
I am looking for insight as to how best apply a pure graphite coating or alternative coating such as Ag to prevent short circuiting as a result of zncl2 reacting.
TTFN
I wil post updates soon.
