NX10.0 - CAM - Machining Simulation Problem
If someone could explain me how to move machining objects with correct positioning on machine table with reference to machining simulation control panel.
a) when i type visualization as : Tool Path Simulate >> the machine is working properly
b) when i type visualization as : Machine Code Simulate >> the machine is not working properly
The milling head is working in the unknow distance from original tool path.
I was trying many methods by changing coordinate system in machine tool navigator (MACHINE BASE / SETUP:part;blank;fixture) according to my MCS.
But still no positive effect...
In operation navigator, when i click on the GEOMETRY tab (geometry view >> watch on top) I see some diferent coordination system than MCS (dont know what it is).
I attach a picture as appendix to this issue.
Best regards
RE: NX10.0 - CAM - Machining Simulation Problem
Hi again,
Problem is almost solved.
It turns out that in NX 8.5 milling tool moves along the path correctly in simulation (Animation : Machine Code Simulate).
For display my issue - watch Attachment
What is the problem? Why in NX10.0 in same .prt file and same 3axis CNC + postprocessor as NX8.5 , machine is going on crazy position...
Some internal NX options, customers deafults?
In Nx8.5 everyhthing works fine
I don't see anything obvious to explain it.
Please log a call with GTAC so that they can look at the details.
Mark Rief
NX CAM Customer Success
Siemens PLM Software
