Selection Set
Selection Set
Selection Set
Can I create a property from my part with a selection set ? For example if I create a propertie called "Producer" that I can choose between 3 different given names? So that you can´t write nothing there, but select an option.
RE: Selection Set
create a string parameter and in the dialog box select Multiple Values instead of single value before you press "Create Parameter of type"
Eric N.
RE: Selection Set
i don´t have this "multiple Values option"
acctually how do you create this parameter? I did it like shown in the attached photo
RE: Selection Set
hi! I already created this parameter as you told. But where can I found again this created parameter? i acctually wanted in the properties.
RE: Selection Set
Thanks a lot. It works also. How could I call this parameter value that I chose in a macro? ...UserRefProperties.Parameter1 ??
RE: Selection Set
....Parameters.Item("String.10") ??
so if my parameter is called string.10 ? I found this in internet but doesn´t function
