Creo Process step bom table
Is there a way when working with a process plan assembly to create a BOM table on the drawing sheet showing ONLY the items added in that step. For example if you have a 300 part assembly, but only add 20 parts from step 3 to 4, can you show a BOM table of these 20 parts without manually filtering other parts out? I'm new to working with this type of assembly and can't see a straight forward way to do this.
Dave
RE: Creo Process step bom table
Use the report parameter prs.actstep.comp.description/name/whatever.
The repeat region needs to be set to the step you want.
