Nodules on a curved surface
Hello everyone,
How can i pattern nodules (small pads) on a curved surface. Creating one nodule is not a problem but if i go with user pattern (i have points where pads need to be) all nodule top flat surfaces end up parallel and i need each one to be normal to the curved surface where points are...
Is there some way I can do this other then going one by one? (need more then 350 pads)
thanks
thanks
RE: Nodules on a curved surface
I would do it with a macro
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
Try defining anchor points in the user pattern.All the best.
Sudhakar.
