stirrups for lintel beam
I have to follow a design of lintel beam with dimensions 3" x 4".
Also, this little structure needs a stirrup as per plan. How can I bend a stirrup that small?
Can I neglect stirrup in this structure?
RE: stirrups for lintel beam
What is are moment and shear values? Can a structural steel lintel be adopted, instead of an RC one?
A good structural engineer is often a blessing for others.
how do you even get anything to calc out with those dimensions?
by the time you account for concrete cover and rebar there will be no moment arm between the steel and the compression zone.
