Is there common stainless 'spring' steel that is magnetic?
Is there a stainless 'spring' steel that is magnetic and machinable? I'm designing a product and need a material with these properties.
Thanks.
Thanks.
RE: Is there common stainless 'spring' steel that is magnetic?
Michael McGuire
http://stainlesssteelforengineers.blogspot.com/
But the real question is how magnetic do you need it?
and how strong do you need it?
You might be better off with a PH stainless (17-7PH in the CH900 condition)
