Conservative choice for in service wood grade?
A colleague of mine is looking to place a heavy load on the wood floor of his 1880s house. The floor joist size is 2"x8" (not nominal) and he believes it is some sort of Pine. I'm conservatively selecting the weakest Pine species from the 2005 NDS manual (if the building is in Chicago, I'm doubtful it's southern Pine). The trouble I'm having is selecting the appropriate grade, as this will have a large impact on capacity. For a home of this age, what is a reasonable choice of grade?
RE: Conservative choice for in service wood grade?
If it was me, I would back into what grade I need it to be based on the loads. Then, if you only need a #2, I would likely assume it was OK, unless I saw something in the member that made me think otherwise.
From what I know about older run of the century lumber, it was generally of much higher grade than we get now. With a rough cut member, if I could inspect the tightness of the grain, I would try to make a case for #1 or better, or even SS. The jurisdiction may require you to downgrade it one or two grades from what it appears.
Mike McCann, PE, SE (WA)
There was some good discussion on this topic recently; Link.
