Modelling a Plate with sinusoidal Displacement Boundary condition in one edge
I am trying to impose a sinusoidal displacement boundary condition in one edge of a plate.
But I am not able to do this ( an amateur User
I'd appreciate it if someone could help me.
| |======> Z=sin(y)
x
|______> y
| |======> Z=sin(y)
x
|______> y
RE: Modelling a Plate with sinusoidal Displacement Boundary condition in one edge
it is an static simlation.
i want just see the deformation of a plate when 2 edges are free and 2 edges have deforming in a sinusodul
shape.
u can define the sinusoidal displacement by using amplitude (instead of ramp) in load definition. then just put u1=1 (if the displacement varies in x direction).
regards
fauzi
@imanhaji
When you define your model with CAE, you can do it with an analytical field. Got into the load module and select Tools->Analytical Field->Expression Field.
See CAE Users Manual 58. The Analytical Field toolset
