How to assign attributes to multiple components of an assembly
Hello NX mates,
I have created an assembly with around 260 child components. Now I need to assign a number of attributes (like description, size, detail no., hardness etc) to each and every component in order to create complete BOM. Is there any easier way to assign attributes to all components at a time (using spread sheet or something like that)other than opening all components and copy/paste/assign attributes individually?
I am new to to attributes and couldn't find any helpful thread yet. Hope my question is clear. Thanks in advance.
RE: How to assign attributes to multiple components of an assembly
Also what version of NX are you running? If it's NX 8.0 or newer, you can use Attribute Templates to pre-assign placeholder attributes with values either left blank or pre-assigned so as to make the process of adding attributes to the final master part files that much more efficient and consistent. And if there are certain attributes which can be one of only a few different values, you cans set-up lists of all the valid attribute values, be they strings, numbers, integers, etc. and then all you have to do is just select from the list the desired attribute value, again something that can speed-up the process of adding attributes to your part files as well as reducing the chance that you've misspelled an attribute name or value.
Trust me, you want to set-up your work flow so that as many attribute as possible are already assigned to your master part files. Adding or changing attributes at the Assembly level should be reserved for only those cases were the attributes assigned to one or more of the Components used in that particular Assembly are different then they would be in any other Assembly. In other words, it's most efficient if you used assigning attributes to the Components of an existing Assembly for only exceptions and Assembly specific cases.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Michael Fernando (CSWE)
www.solidCADworks.com
Tool and Die Designer
Siemens NX V9.0 + PDW
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
Thanks for the inputs. I am using NX8.0. Assume that currently I am following the procedure you described above. I have set required attributes in customer defaults, hence when ever I create a new part the attributes are added to the component under Unset category. Then I select each attributes giving value to them. Thru this I have saved little bit time that I had spent earlier in this process as earlier I was typing/copy/pate attributes to each component.
Thank you.
Can you please explain the procedure you use for the same? Also do you have any idea that will it work with Moldwizard BOM also?
File -> Utilities -> Attribute Templates...
...and with 'Part File' option toggled ON, create the desired attributes which can either be left bland or with default values. Then save your template parts and you're good to go.
OR, you open any part file and go to the same place as above, only now select the 'Catalog' option and then create the desired template attributes.
Now set-up your desired attributes like above and when you're done, in the 'Actions' section of the dialog, save the 'Catalog'.
Then go to...
Customer Defaults -> Gateway -> User Attributes
...and define the path to these catalogs. Now when you open any part file, even existing parts, the attributes in the Catalog template will be available in as Unset attributes.
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
So try the following.
1. Insert a part list inside your main assembly
2. In the Part List add new columns
3. With column settings, designate each new column/s with the attributes you want to edit or add
4. Now click the MW/PDW’s “Bill of MAT” icon and you will see a spread sheet with all the columns and rows as your Part list.
5. In the spreadsheet double click the cells and edit/add values.
6. When you close the BOM Spread sheet, it will update the parts with new attributes.
Hope this will work for you.
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
ADDING_ATTRIBUTES
REGARDS,
GANESH
That was cool!!! The time which was required to add attributes reduced a lot. It works with Moldwizard also.
Thank you so much...
Yes I was following the same procedure. But the catalog option you elaborated was new to me. Thanks a lot for your reply.
However the procedure which MFDO described above is much easier than this for bulk attribute adding/editting.
Thanks for the reference thread. I don't know much about journals but will try using that one.
It will be great if you could teach me where to define attributes as per my requirements in this journal file. Or shall I just copy paste that one?
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Please Save attached journal to you hard drive or net work drive (this journal from some where in these posts)
then go Tools -> Journal -> play. It will pop up one window there browse the journal which you save and press run. It will add attributes specified in journal.
This journal will scan all the components in assembly and add "ORDER" attribute to each component in assembly and it will ask value of order you can enter user value in the box.
If you need any specific attributes and values according to that you have to alter the journal or let me know what attributes and values you want to add in components
nOTE
GANESH KOTHAKOTA
CAD/CAM LEAD
TECHMAHINDRA
This kind of useful basic functionality should be included in the NX Base Package. What do you think?
Probably most guys don’t know what I’m talking about, because they haven’t seen it working!
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
Thank you for the journal file and procedure to use it.
www.cadroad.com
That's what I mentioned in post Tools->journal->play....
GANESH KOTHAKOTA
CAD/CAM LEAD
TECHMAHINDRA
This is how many clicks per one attribute? Then for the whole project = #of clicks x #of attributes X # of parts ( e.g. 11 x ~4 x 260 = 11,400 clicks minimum). So you think this is an efficient way to work!
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
Yes, this is an efficient way of work. Because you missed one important point in my video - I selected multiple parts before assigning attribute. So your fancy maths amounts only for #of clicks x #of attributes = 88 clicks. I am sorry to sink yet another your NX-bashing SW-promoting expedition.
www.cadroad.com
You missed the point! I was comparing NX’s own MW/PDW method to conventional method you showed. Out of the blue you are saying I’m trying to promote SWx. Why do you hate SWx so much?
As you say, if I want to bash NX, then why did I submit 7 ERs in the last month alone? (Since John showed me how to submit ERs) It’s only to make my and other NX users’ life easier. It’s true that some ERs are based on my past experience and if they are implemented, I'm sure you will be happy and will be in a better position.
SWX 2013 SP3.0 X64
PDMWorks 2013
Logopress3
FastForm Advance
FormatWorks
www.cadroad.com
One more support request from you. I completed the attributes stage and BOM creation in NX. Now my customer wants the BOM in excel sheet. I tried it using Moldwizard BOM button and selecting entire rows the n right click and export to Excel. But below message was displaying:
No BOM template file was found NX8.0
And if I select "OK" in that dialogue box, the action gets cancelled. Please suggest how to overcome this or any other method to export the BOM into excel.
As of now I did it by selecting some rows then copy then open one excel sheet then paste. But unable to select much rows only 10~15 rows at a time.
http://www.eng-tips.com/viewthread.cfm?qid=166468
GANESH KOTHAKOTA
CAD/CAM LEAD
NX8.5, Vericut7.3.1
TECHMAHINDRA
Thank you.. It worked...
