Reuse of Bolts
Reuse of Bolts
Anywhere, any code has prohibited reuse of high strength bolts?
Please if you know reference it.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Reuse of Bolts
RE: Reuse of Bolts
https://www.aisc.org/DynamicTaxonomyFAQs.aspx?id=1...
RE: Reuse of Bolts
RE: Reuse of Bolts
The practice in my company is if the bolt or screw is below 75% of yield then its reusable, anything above that and its replaced.
In fact from my point of view and where possible I would always fit new fasteners.
RE: Reuse of Bolts
RE: Reuse of Bolts
Some of the suspension and brake parts on my old Volvo came factory equipped with thread locking guck applied.
The factory manual forbids their re-use. The torque spec is well below yield.
My belief is the loss of thread locking compound is behind the one use rule in that case.
RE: Reuse of Bolts
Turn-of-nut and use with new DTIs (squirting washers) should still work for tensioning. snug-tight shouldn't be a problem.
