ABAQUS PDE not working
I am trying to use Abaqus PDE to run the abaqus CAE.
When i open abaqus cae, I go to file and open Abaqus PDE. But in Abaqus pde i found that the recording button is not available for recording.
Secondly when i write a script and run the code by pushing the play button, then i got following error
*** Error - remote process did not start
Please advice me where I am wrong?
RE: ABAQUS PDE not working
But the thing i like in PDE is that you can run single line at a time and visually see it in abaqus cae.
infact you can also create a time lapse between execution of command and that what i want.
this operations are not possible with external editor because in that case you need to run the whole script once and thus can't visually see every action at a time
if this thing is possible without pde then please let me know
