Low temperature ASME VIII
I would appreciate your help on ASME VIII Div 1:
The scenario is: Carbon steel vessel with thickness of 60 mm and a minimum T of - 70°C during depressurization. Based on ASME VIII Div 1 UCS-66 is possible an exemption of impact test because the stress ratio is lower than 0.35.
Is the exemption applicable also to the weld metal?
Thanks in advance
V.
RE: Low temperature ASME VIII
Yes, review UCS-66.
Is this stress ratio based on vessel at MAWP ( without taking credit for corrosion allowance) or depressurisation final pressure?
