Acces a created property from a part in a drawing from catia with makro
I added new properties to my part like Material, Department, etc. and gave them values.
Now I made the drawing from this part with some Textboxes. I want a macro that displays the values of my properties in this tex tboxs.
I found a Makro that is very similar from what I need, though it acces the Name of the part and the name of the file, not the properties.
They used this code to acces this ones:
vTXT = Left(oName, InStrRev(oName, ".CAT") - 1)
Name_1 = mid(vTXT, InStrRev(vTXT, "_") +1) 'Right Left Mid
Namex = Left(vTXT, InStrRev(vTXT, "_") -1) 'Right Left Mid
Name_2 = mid(Namex, InStrRev(Namex, "_") +1) 'Right Left Mid
Is there something like this to acces the properties?
Thank you!
here is the whole Code:
Sub CATMain()
If CATIA.Documents.Count = 0 Then
Box = MsgBox("Es wurde kein aktives Dokument identifiziert" + Chr(10) + "Bitte oeffnen Sie zuerst ein Dokument und starten Sie dann das Makro erneut", vbInformation, "Hinweis")
Exit Sub
End If
For i = 1 To CATIA.Documents.Count
Dim oDocument As Document
Exit Sub
End If
Set oDocument = CATIA.ActiveDocument
If TypeName(oDocument) = "PartDocument" Then
PartDoc
If ErrorReturn = 1 Then
Exit Sub
End If
oDocument.Close
End If
Exit Sub
End If
If TypeName(oDocument) = "ProductDocument" Then
ProductDoc
Exit Sub
End If
oDocument.Close
End If
Exit Sub
End If
If TypeName(oDocument) = "DrawingDocument" Then
'__________________Ansicht bestimmen_________________________________
Dim oDrwDocument As Document
Set oDrwDocument = CATIA.ActiveDocument
Dim oDrwSheets As DrawingSheets
Set oDrwSheets = oDrwDocument.Sheets
Dim oDrwSheet As DrawingSheet
oDrwDocument.Sheets.Item(1).Activate
Set oDrwSheet = oDrwSheets.ActiveSheet
Dim oViews As DrawingViews
Set oViews = oDrwSheet.Views
Dim oView As DrawingView
Set oView = oViews.ActiveView
oView.Activate
'_______________________________________________________________
'__________________________Dateipfad LESEN___________________________________________
If oDrwSheets.Parent.Path = "" Then
Mldg_1 = "Die aktive Zeichnung hat keine externen Refenzen"
Mldg_2 = "Bitte schließen Sie alle Zeichnung die nicht auf CATParts oder CATProduct verlinkt sind und starten Sie das Makro erneut"
Mldg_3 = "Das Makro wird nun beendet!"
Stil = vbOKOnly + vbCritical
Titel = "Abbruch"
Box = MsgBox(Mldg_1 + Chr(10) + Mldg_2 + Chr(10) + Mldg_3, Stil, Titel)
Exit Sub
End If
Set ProductDrawn = oDrwSheet.Views.Item("Vorderansicht").GenerativeBehavior.Document
oPath = ProductDrawn.Parent.FullName
oName = ProductDrawn.Parent.Name
'__________________________________ STRING zerlegen ____________________________
On Error Resume Next
'________________________________________________________________________________________
'__________________Auf Blatt 2 wechseln_________________________________
Set oDraw = CATIA.ActiveDocument ' Zeichnung als aktives Dokument bestimmen
Set oSheets = oDraw.Sheets
oDraw.Sheets.Item(1).Activate
Set oSheet = oSheets.ActiveSheet
oSheet.Activate
Dim j As Integer
Dim oText As DrawingText
Dim ocText As DrawingTexts
'__________________Alle Views ablaufen und nach Texten suchen_________________________________
For k = 1 To oDraw.Sheets.Count 'Schleife fuer alle Sheets
Set oSheet = oDraw.Sheets.Item(k)
'If oSheet.IsDetail Then 'Ist das Sheet kein Detail-Sheet?
For j = 1 To oSheet.Views.Count 'Schleife fuer alle Views im Sheet
Set oView = oSheet.Views.Item(j)
Set ocText = oView.Texts
Z = 0
For s = 1 To ocText.Count
Set oText = ocText.Item(s)
If oText.Name = "Benennung" Then
oText.Text = Name_1
Z = 1
End If
if oText.Name = "Zeich-Nr" Then
oText.Text = Name_2
Z = 1
End If
Next
Next
'End If
Next
'Box = MsgBox ( Z)
'______________________________ Text suchen und ueberschreiben __________________________________
'__________________In den Vordergrund wecheln_________________________________
Dim ErrorFrame As Integer
oSheet.Activate
Set oViews = oSheet.Views
oSheet.Views.Item(1).Activate ' BLATT001 aktivieren
Set oView = oViews.Item(1)
oView.Activate
ErrorFrame = 0
If Z <> 1 Then
'Box = MsgBox("Der passende Zeichnungsrahmen wurde nicht gefunden, bzw. die Textfelder im Schriftfeld wurden umbenannt." + Chr(10) + "Bitte tauschen Sie den Rahmen gegen aktuellen Zeichnungsrahmen mit aktuellen Schriftfeld", vbCritical, "Abbruch")
ErrorFrame = 1
End If
'__________________________________Aufteilung Dateiname & Dateipfad____________________________
Dim nName As String
nName = Left(oPath, InStrRev(oPath, ".CAT") - 1)
'__________________________________Zeichnung speichern____________________________
CATIA.DisplayFileAlerts = False
Datei = nName & ".CATDrawing"
CATIA.ActiveDocument.SaveAs (Datei)
'__________________________________Message Box____________________________
Dim oFile As String
Dim nDoc As Document
If ErrorFrame = 1 Then
Mldg_1 = "Die Zeichnung wurde erfolgreich gespeichert."
Mldg_2 = "Zeichnungspfad: " & Datei
'Mldg_3 = "Das Schriftfeld konnte nicht aktualisiert werden!"
Stil = vbOKOnly + vbInformation
Titel = "Hinweis"
'Box = MsgBox(Mldg_1 + Chr(10) + Chr(10) + Mldg_2 + Chr(10) + Chr(10) + Mldg_3, Stil, Titel)
Else
'Mldg_4 = "Das Schriftfeld wurde erfolgreich synchronisiert!"
Titel = "Hinweis"
'Box = MsgBox(Mldg_1 + Chr(10) + Chr(10) + Mldg_2 + Chr(10) + Chr(10) + Mldg_4, Stil, Titel)
End If
'__________________________________Zeichnung schließen____________________________
End If
Next
'__________________________________Fehlerbehandlungen____________________________
End Sub
Sub PartDoc()
Dim oDoc As PartDocument
Dim Name As String
ErrorReturn = 0
Set oDoc = CATIA.ActiveDocument
Name = oDoc.Path
If Name = "" Then
sDoc = CATIA.FileSelectionBox("Datei Speichern", "*.CATPart", CatFileSelectionModeSave)
If sDoc = "" Then
Box = MsgBox("Sie haben das Speichern des Dokumentes abgebrochen" + Chr(10) + "Das Makro kann nicht weiter ausgefuehrt werden!" + Chr(10) + "Bitte speichern Sie das Dokument ab und starten Sie das Makro erneut", vbCritical, "Abbruch")
ErrorReturn = 1
Exit Sub
End If
oDoc.SaveAs (sDoc)
Else
oDoc.Save
End If
End Sub
Sub ProductDoc()
Dim oDoc As ProductDocument
Dim Name As String
ErrorReturn = 0
Name = oDoc.Path
If Name = "" Then
sDoc = CATIA.FileSelectionBox("Datei Speichern", "*.CATProduct", CatFileSelectionModeSave)
If sDoc = "" Then
ErrorReturn = 1
Exit Sub
End If
oDoc.SaveAs (sDoc)
Else
oDoc.Save
End If
End Sub
Sub Zeichnung()
End Sub
Thank you!
Sub CATMain()
Exit Sub
End If
Exit Sub
End If
PartDoc
Exit Sub
End If
oDocument.Close
End If
Exit Sub
End If
ProductDoc
Exit Sub
End If
oDocument.Close
End If
Exit Sub
End If
oView.Activate
Titel = "Abbruch"
Exit Sub
End If
oSheet.Activate
Dim j As Integer
Z = 0
oText.Text = Name_1
Z = 1
End If
oText.Text = Name_2
Z = 1
End If
Next
Next
'End If
Next
'Box = MsgBox ( Z)
oSheet.Activate
oView.Activate
ErrorFrame = 0
If Z <> 1 Then
ErrorFrame = 1
End If
Dim nName As String
Dim oFile As String
Titel = "Hinweis"
Else
Titel = "Hinweis"
End If
End If
Next
End Sub
Sub PartDoc()
Dim Name As String
ErrorReturn = 0
Name = oDoc.Path
If Name = "" Then
If sDoc = "" Then
ErrorReturn = 1
Exit Sub
End If
oDoc.SaveAs (sDoc)
Else
oDoc.Save
End If
End Sub
Sub ProductDoc()
Dim Name As String
ErrorReturn = 0
Name = oDoc.Path
If Name = "" Then
If sDoc = "" Then
ErrorReturn = 1
Exit Sub
End If
oDoc.SaveAs (sDoc)
Else
oDoc.Save
End If
End Sub
Sub Zeichnung()
End Sub
RE: Acces a created property from a part in a drawing from catia with makro
http://www.eng-tips.com/viewthread.cfm?qid=381431
