sewing surfaces into a solid
I'm a little confused how to join a solid to a sheet quickly. I'm using a ton of steps sometimes to get there.
Attach is a crude example where there is a bottom solid curved piece and then there is a top that is built with sheets, it only lacks a bottom. Therefore, there is a sheet on top of a solid. I'd like to use the same exact surface as the top side of the solid in this example. Is there a command or a quick way to "SHARE" the solids surface with the sheet?
nx 9
RE: sewing surfaces into a solid
If you want to make one solid body from the solid + sheets, the "patch" command will save a step (try reversing the direction of the target region to remove option or selecting a different tool direction face if the result is not quite what you were expecting).
www.nxjournaling.com
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Tim Flater
NX Designer
NX 9.0.2.5 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
nx 9
