modelling prestress
modelling prestress
Hello all,
I am a new forum member and a relatively new user of Abaqus and I am trying to incorporate residual stresses in my numerical model. I am modelling a fully toughened glass plate with solid elements subjected to out of plane loads. The residual stresses are only changing through the thickness of the glass plate and have the shape of a parabola (compression on the outer surfaces and tension in the middle).
Any ideas on how to do that?
Thanks a lot in advance,
Korina
Korina
RE: modelling prestress
You have a part, you have a load and you want to create stresses. So why don't you do the simulation?
If you read my question again you will see clearly that I'm asking about incorporating prestress in my model.
Fyi fully toughened glass is safety heat treated glass that has a favourable stress profile through its thickness (that's the parabolic stress profile I mentioned in my previous post).
Is there any way of incorporating this on Abaqus CAE without creating a separate step with temperature loading?
But usually it is easier to do a thermal analysis and to apply the temperature history during a static step to get the stresses.
