interactions among simulink and mySql
Good evening , as the title I'm trying to extract some datas on a mySQL database.
I managed to get the data in the command window , but I'd like to do the same using simulink in real time . Searching the web I found several solutions including the use of the block " Level - 2 S-function " in Simulink . Since following this road I'm finding a lot of difficulty , I would like to know if this approach is correct or is there a better solution .
