How can I set up and investigate heat transfer properties of porous structures using tube furnace?
How can I set up and investigate thermal properties, heat transfer and their enhancement in porous ceramic and metallic structures using a split tube electrical furnace (3-zone)?
We want to install the set up as soon as possible. We would like to investigate their porosity on the heat transfer properties. We have already MFC for gas flow control and the tube furnace. We have interested in conducting various heat transfer measurements e.g. radial, effective….and so on. Is there another easy set up that you can recommend?
Thank you
