CATIA check if a selection is empty
Hi there !
I'm using an InputBox to search a plane in my Tree,
Problem is I don't want to do anything before I'm sure that plane exists
Is there a function or something to test if the Plane exists or not ?
thanks
thanks
RE: CATIA check if a selection is empty
CODE -->
Do While Nom = False namer = Inputbox("First, please make sure that you activated the DSE licence for CATIA (Tools/Option/General/Shareable Products), then, Please enter the EXACT name of the Point Cloud you want to divide.") oSelection.Search "Name=" & namer If (oSelection.count = 0) then x=msgbox("The Entity you are looking for does not exist" ,48, "Wrong Input") Nom = False oSelection.Clear Else Nom = True oSelection.Clear End If Loop
