Pump Pressure and Head
The energy provided by a pump is measured in terms of head. This is independent of the liquid density. How would you prove this from a mathematical point of view. The formula for static head has a density term in it. So then how could head not be related to density. Any help clarifying this would be appreciated.
RE: Pump Pressure and Head
Watts = Q x rho x g x h / E
Q = m3/sec
rho = kg/m3
g = 9.81 m/sec2
h = head produced at Q
E= efficiency (as a ratio, not %)
This W is plain absorbed power - there are other adders to account for seal losses, gearboxes and couplings, etc.
Yes, in a centrifugal pump, the head developed is independant of density, but there may be some corrections required for viscous fluids when internal slippage becomes significant. This comment refers to newtonian fluids only.
Read this link it may help:-
http://www.pumpfundamentals.com/yahoo/The%20influe...
As the other above say, you have mistaken the head figure for energy. Head is head (m), not energy. Only once something starts moving then the density term comes into play.
Head from a centrifugal pump is a function of impellor diameter, impellor shape and rotational speed. It generates a velocity which translates into head - a distance. Distance cannot be energy.
If the pump is not flowing and the outlet is blocked, there is still head / pressure, but no energy in the fluid.
When I first started looking at pump design and operation it took me some time to get my head around the head concept, but when you do, it all starts to make sense.
Energy supplied to the fluid is very much dependent on the fluid density. You can observe this easily by measuring and comparing motor amps in cases when you pump the same amount of gasoline (d=0.75) and water (d=1.0).
Lifting 1 cubic meter of feathers does not require the same energy as lifting one cube of steel. E=m*g*dH
H is the same in both cases, but the energy is not.
Dejan IVANOVIC
Process Engineer, MSChE
KE = 1/2 * m * v^2
with mass = 1 lbm, then KE = 1/2 * v^2
KE also = m * g * h, when in a gravitational field and h = height above datum
mgh = 1/2 m v^2, which for a mass of 1 lbm
where h is "head".
head therefore = v^2 / 2 / g
Kinetic Energy is not independent of mass.
Head is independent of mass, because Head is defined as the kinetic energy PER UNIT MASS.
PE in a gravitational field = mgh
If I wanted to gdetermine the flowrate directly at the outlet of a centrifugal pump that is in operation, I could do the following:
(For the purposes of this first scenario lets assume that I have a pressure gauge (bourdon mechanical) at the pump inlet and outlet and I know the fluid velocities at both the pump inlet and outlet).
- Convert the gauge readings to static head and add the relevant dynamic head terms to the inlet and outlet static heads (I believe that the gauge doesn't account for dynamic head if the liquid is flowing?). Then subtract the calculated suction head from the discharge head to determine the pump differential head. Then I can read the flowrate from the pump curve.
If I wanted to determine the pump shut off head I could
- Close a valve on the outlet of the pump that is downstream from the pressure gauge (the idea being to reduce the velocity to 0, so that any velocity head (dynamic) terms on the suction or discharge side of the pump become zero due to zero flowrate). Then use the gauge readings to work out the suction static head and discharge static head. Then subtract inlet from outlet which would give me the shut off head for the pump.
I don't know how right or wrong I am with the above approaches but would appreciate any comments.
If you have the velocity of the fluid at the pump outlet then if you just multiply that by the area of the outlet you will obtain the volumetric flow rate.
I understand that different pumps can give much different flowrates even though the pressures may be similar. However if the pressures are similar and if the head is also similar then is this not where the pump curve for the specific pump in question comes into play?. The pressures/head may be similar for 2 totally different size pumps but when the pump curve is referenced then a similar head for 2 different pumps can yield a totally different flowrate depending on the curve that is specific to the pump in question.
In most situations that I encounter the only thing I have to reference is a pressure gauge/s near the pump and a pump curve (Head v flowrate). So if my above thinking is not correct then how would I use the pressure gauges to ultimately work out the flowrate (assuming I don't know any velocities at the pump inlet flange or outlet).
So in that case, yes you can estimate the flow rate based on the differential pressure converted to head. It might get tricky on a flat part of the curve.
