NX tool overlap maximum when using reference tools.
Hello all,
The docs say "The applied Overlap Distance value is limited to the tool radius" for both z-level profile reference tool overlap and flow cut reference tool overlap. I assume it refers to the radius of the programmed tool diameter and not the reference tool but I am not completely sure. Can anyone clarify this for me?
NX9
Migrate to 10 when 10.2 is released.
RE: NX tool overlap maximum when using reference tools.
Hint: Whenever you see the pull down option for part units (in/mm) or %Tool, it is based on the cutting tool diameter.
The overlap distance seen with the reference tool selection is a percent of the reference tool diameter.
Mark Rief
NX CAM Customer Success
Siemens PLM Software
