Pressure Regulator Setting
Hi Good Day,
I have a 535H pressure regulator with a bench range setting from 2-10 PSI.Can I be able to set at the regulator at the low end 2PSI setting OR would its repeatability be affected?
Appreciate your feedback.
RE: Pressure Regulator Setting
Dejan IVANOVIC
Process Engineer, MSChE
Make sure that the regulated output pressure is set at a 'working' flow rate. An output adjustment at zero flow rate will bump to a different level when flowing.
Dejan IVANOVIC
