do you design column and beam splice to 1/2 or 2/3 of its capacity?
steel structure book by salmon recommends this.
I saw a columns splice for an NFL stadium (not the stadium itself but the ramp/escalator building) and i am sure it's not designed to at least 50% column capacity.
splice plate only has 6 bolts for the upper W12 column, welded to bottom column.
RE: do you design column and beam splice to 1/2 or 2/3 of its capacity?
If I don't, I'll give some consideration to splice stiffness, even if it's just conceptual. Many splices occur in members for which buckling/LTB is a possible failure mode. In those cases, stiffness of the splice can potentially come into play. I've always considered the 1/2 - 1/3 business to be an indirect way to ensure some stiffness in the splice.
