Heat Exchanger Design
ANy tips as to how can I estimate the thickness of the heat exchanger unit having the following dimensions.
height of 9m length of 20 m and 2.5 m wide
The process details are as follows
Shell Side,
Flue gas
Mass flow 500 Kg/s
Inlet P 1.04 bara Outlet P 1.00 bara
Inlet T 540 deg C outlet T 200 deg C
Tube side
Sea water
Volume flow 21400 m3/h
Inlet P 1.9 bara Outlet P 1.65 bara
Inlet T 103 deg C outlet T 110 deg C
I need to estimate the thickness so i can determine the weight of the unit and make a rough estimate of the price..
Any suggestions/ideas will be useful.
Thank you
Kind Regards
Puneet
Shell Side,
Flue gas
Mass flow 500 Kg/s
Tube side
Sea water
Thank you
Kind Regards
Puneet
RE: Heat Exchanger Design
The shell is a rectangular box
Header Box of Air Fin coolers are designed as per this same.
TEMA can not be made applicable for this exchanger as Cross Section is not Circular.
VK (Mechanical)
