Pipe Risers Height
Pipe Risers Height
Hi All,
At our gas plant, I have seen some pipes connected to the underground drain with flange connections just inches aboveground (3-5"). Is this a good practice for installing pipe risers?
RE: Pipe Risers Height
Where this reference of 12" can be found in order to implement this recommendation?
I don't think you will find this under any code but is often referenced in various Client & Contractor Specification and additional to previous replies there has to be sufficient envelope to insert and remove bolting.
Regards.
Mick.
