about thermal diffusivity
if thermal diffusivity is much greater.....what is predicted regarding the temp of the body?...will it be higher...as the cp in denominator is higher?...ans specifically to the point raised pls.
RE: about thermal diffusivity
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
