Time & Date Stamp on printed Drawings
1000 points to the first person who can give me a simple way to put a print time & date stamp on my drawings.
Ho3
RE: Time & Date Stamp on printed Drawings
Embed an Excel sheet with =NOW() in a cell. The sheet won't reevaluate until you access it, so create a macro that accesses it, then prints the drawing. All you have to do is then run the macro.
When the Header/Footer dialogue window comes up, select where you want your date and time, and in what format.
"The attempt and not the deed confounds us."
I finally discovered that this is saved in the DOCUMENT TEMPLATE.
This was one-of-those-things; I knew there had to be a simple solution.
tatej@usfilter.com
Andrew
No macro needed. Do what MadMango said in your template. Print the template to set the date & time. Now save your template.
Bradley
