Weld Repair in the SAW weld seam of Spiral Steel Pipe
Is Allowable to do a weld repair in defect type melt througth,using qualified FCAW process?
RE: Weld Repair in the SAW weld seam of Spiral Steel Pipe
Most likely not. I would reject it.
Far better to cut it out.
Tks BigInch, we will consider your recomendation to stutus definition of pipes with this type of defective welds.
