Round Column with Multiple Compression Braces
I am working on a project which involves analyzing and load rating a series of existing industrial mezzanines. Due to the configuration of the "bracing", I have 3 or even 4 braces in compression simultaneously that frame into the round columns at the same elevation. I am trying to determine the capacity of the column in that location, but have not found any information in AISC, AISC DG 24 or CIDECT DGs that indicates how to check wall plastification when there are multiple loads at the same elevation on the column. Attached are a few pictures that show what I am looking at.
Can anyone point me in the right direction or provide any insight?
RE: Round Column with Multiple Compression Braces
For the design loading, calculate the resultant the resultant force of the 3 braces simultaneously.
Then ignore 1 brace at a time and calculate the resultant of all combinations of 2 braces simultaneously.
Finally, ignore 2 braces at a time and examine each remaining brace, by itself.
For four braces, add an extra step to the same approach.
You will might see a general pattern to the results, but one case may stand out as unusually significant. Even if you don't see anything noteworthy, you will get an improved understanding of how the column is being loaded. That insight can lead to reasonable assumptions that can be solved. Better than looking indefinitely for an ideal solution... that may not exist.
www.SlideRuleEra.net
www.VacuumTubeEra.net
