View Break always out of date
I am using NX 8.0 and I have a drawing that includes a number of "View Breaks", I have noticed that one particular view is always "Out of Date". I can update the view and it will stay updated until I change sheets at which point it goes out of date again. In trying to figure out why this one view is different from the others I have determined that it must be related to a dimension I have that spans the break. If I delete the dimension, the view no longer shows that it is "Out of Date" when I switch sheets, however the sheet itself says that it is "Out of Date" until I update that particular view.
I think this may be related to thread561-358441: Broken Views NX 8.5, (I had similar issues to that thread, but I found if I had the problem sheet open and updated the problem did not occur). Has solution been found? If it is fixed in NX 10 are there plans to update NX 9 and 8?
