Physical properties of materials list wanted
Hi
Anyone know of any good extensive, up to date and "scientific approved" material properties list on the web? One that would be okay to refer to in a Master thesis.
I am looking for a list with many properties for each material. Heat capacity, density, electrical resistance, elastic modulus etc etc.
RE: Physical properties of materials list wanted
Look in some of the papers that you are referencing and see who they cite for data.
Most of what I have is actually in published (paper) formats, because it is old. But then these are properties that don't change so the data is still valid.
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Always when I look for any kind of property for a material I need to find a new source.
EdStainless reply was helpful anyways, I also found "http://www.matweb.com" by googling in a way that made the promoted sites go away. Thank you anyways :)
TTFN
MMPDS will give you mechanical properties and modulus data.
CINDAS is mostly thermophysical properties.
