Catia vbscript How to set a searched planar section as a reference
hi everyone,
I wanted to know if it was possible to look for a planar section knowing its name and then use the selection as a reference in a rotation for exemple.
I mean for a rotation you need 2 references : something to move and an axis.
Is it possible to select something to move and make this be the reference for the rotation using
CODE -->
oSelection2.Search "Name=" & "Planar Sections." & k & "*,all"
RE: Catia vbscript How to set a searched planar section as a reference
up ?
