How to Calculate Stresses in Rectilinear Pressurized Channel
Materials, dimensions and design conditions are shown on the attached drawing. I have taken a two-dimensional slice of the pressurized channel to simplify the analysis. It is a Section VIII-D1 pressure vessel.
Short of having professional software, how do I go about obtaining conservative values of the stresses? Seems to me I will need to consider vertical and horizontal loads on the four sides, as well as bending loads at the welds. Can I treat the latter portion as a beam under uniform loading?
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
RE: How to Calculate Stresses in Rectilinear Pressurized Channel
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
My task is only to do a FFS assessment.
