Is it possible to remove the ANSYS logo in the top right corner?
In ANSYS meshing and especially in Mechanical there is the ANSYS with the release number at the top right corner. Is it possible to remove this and replace it with a company logo?
Thanks.
RE: Is it possible to remove the ANSYS logo in the top right corner?
Hi arnie333,
Tried this, doesnt work.
Tried it again now, it works, dont know what was wrong the last time I tried it.
Thanks.
BTW - the directory is "images" and not "bitmaps" as stated in the link.
I changed the logo, it looks good in meshing, mechanical, DM and CFD-POST, but for some reason in FLUENT it completely distorts the image.
Are there any specific image size requirements for this to work in fluent?
Thanks.
Hello assafwei!
The rest “C:\Program Files\ANSYS Inc\v121\aisol\CommonFiles\Bitmaps\” is correct? Until Bitmaps folder? What version of Ansys are you using? I'm asking you this because in v16 and v15 in the "CommonFiles" folder you cant find either "Bitmaps" or "Images" folder.
Thank you!
The correct directory is: "C:\Program Files\ANSYS Inc\v160\commonfiles\images"
The file name is not the one stated in the link, it is "ANSYS_wht_lrg.png"
Thanks!
