ITE 15 HK 500 racking procedure
What do you fell is safer in racking in a 15HK500 bkr.
1. Control power fuses in and door shut, racking Bkr all the way to connect.mind you springs charge when you reach test. Or
2. Racking breaker in with fuses out and after reaching connect, open door and install control power fuses. Springs charge when fuses installed.
RE: ITE 15 HK 500 racking procedure
old field guy
