Test Limitations
Test Limitations
Hi All,
For a 15,000 PSI Chart recorder, at what percentage of the chart should be the safe test pressure prior to getting a recorder with a higher range.
For example, I want to test an item at 13000 PSI,can I use the 15000 PSI recorder or will I need to get one with a higher static range?
Thanks and Appreciate your feedback.
RE: Test Limitations
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
Overpressuring a mechanical sensor usually ruins it for measurement purposes.
The accuracy of a mechanical sensing pressure recorder (bourdon tube, spiral tube) is percent full scale (%FS).
Likewise, the accuracy of electronic pressure transmitters that send a signal to a recorder is %FS.
For %FS measurements, the closer the measurement is to full scale, the better the accuracy (the less the uncertainty).
