Remove all tree structure without exporting as part.
NX 10 Is there a way to remove all of the tree structure in a part without having to export as a part?
Thanks B.
Thanks B.
RE: Remove all tree structure without exporting as part.
Use with caution.
www.nxjournaling.com
Sometimes I also just export a part and check the remove parameters method to save a copy, that way I have the original if I need it.
B.
