Engraving a picture on a machined part
How do you take a 2D sketch, like an imported dxf picture or dxf logo, and engrave it onto a part? The part will then be read by mastercam for machining on a mill. I know how to extrude a cut to a surface using a closed contour sketch, but what if the dxf picture is made with many lines, not closed contours. Mastercam understands the 2d dxf, but how do I get a 2d dxf picture to be a part of my solidworks model which then can be imported into mastercam for applying toolpaths?
RE: Engraving a picture on a machined part
What exactly is this?
A picture or a logo?
tatej@usfilter.com
