NX 8.5 Translators
NX 8.5 Translators
When I try to run any of the NX translators from the start menu, I receive an error to do with java runtime enviroment and its location, see attached image. What settings do I need to agjust in NX?
Rob
(Die Design Professional
Rob
RE: NX 8.5 Translators
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Rob
Rob
http://files.engineering.com/getfile.aspx?folder=5...
John R. Baker, P.E.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
"One more thing to consider..."
If the release notes for your NX version say Java 1.7 then before calling GTAC I would try use JAVA 1.7 of the same architecture (32/64 bit) as NX.
I have seen where upgrading to Java 1.8 and then Oracle post-installation "removing old Java versions" has removed the 1.7 Java version that older NX installations expected. (The message about meeting the minimum is correct (but it is not the entire expectation.))
HTH,
Joe
