Frequency response analysis
If a frequency response analysis on a modal basis is done in a certain range (eg. 0-5000 Hz) how many vibration modes to be calculated so that the analysis is valid?
You can use a number of ways to recruit the 90% of the total mass, although this does not cover the entire frequency range?
RE: Frequency response analysis
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
