Quick Drawing Question
I was wondering if it is fine to call out chamfers and surface roughness in this way (having a dot on a surface) VS showing a different view with an arrow pointing to that surface. Are there any standards for this? Also I know the "all around" surface roughness callout is not legit so i dont want to get into a debate about that.. Thanks. See images.
RE: Quick Drawing Question
Make it as clear as possible for the machinist.
Chris, CSWA
SolidWorks '15
SolidWorks Legion
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Putting an upper and lower finish requirement is very unusual, meaning if you got a 16 finish you would have to roughen the surface. Normally you should put 64 finish meaning you want 64 finish or better and not a lower limit.
Bill Pearson CMfgE
