MECHANICAL BEARING MONITOR
I WANT TO KNOW IN DETAIL THE PRINCIPLE OF OPERATION OF THIS MECHANICAL BEARING MONITOR
http://www.nikkiso.com/products/pump/canned/option...
THANKS
THANKS
RE: MECHANICAL BEARING MONITOR
"The end of the monitor has a contact tip which is fitted within a cavity in the end nut on the rotor shaft. Clearances between the contact tip and the end nut correspond to the maximum allowable bearing wear. At maximum allowable bearing wear the tip is contacted and ruptured. In addition, the monitor is useful in detecting corrosion of the stator liner and rotor sleeve since the contact tip is supplied in the similar metallurgy by one-half the thickness of those components."
Rupture of the diaphragm releases the stored nitrogen pressure and this registers on the pressure gage.
