ASME Sec 8 Div 1 Threaded Endplate
I have included a screen capture of a threaded end cap for an ASME Sec 8 Div 1 pressure vessel that the company I work for has manufactured for a very long time. Recently we have been questioned on the wall thickness of the shell at the threads. I have looked at UG-31 but this seems to apply to shell wall thickness with exposed threads whereas our design has no exposed threads. I can't seem to find anything in the code that I can use to verify the reinforcement that the threaded nut adds to the wall thickness under the threaded portion of the vessel. Does anyone have experience with this or know of code/code case that would address this?
RE: ASME Sec 8 Div 1 Threaded Endplate
Mike
