machine Laser fo 3015 discharge
I have a problem in the machine Laser fo 3015, the machine will discharge almost 5 times a day, usually there is a bad contact at the KM2 contactor. LASAL or gas pressure (if you like it is the normal pressure to the bottle LASAL 2003)
