NI Labview, SignalExpress, Power Spectrum (Spectra)
RE: NI Labview, SignalExpress, Power Spectrum (Spectra)
would you please explain it "mathematically" ?
thanks.
Please refrain from double posting. Your question was already answered: thread31-384452: Need Help. NI Labview, SignalExpress, power spectrum (spectra)
TTFN
Of course I can. I can do anything. I can do absolutely anything. I'm an expert!
There is a homework forum hosted by engineering.com: http://www.engineering.com/AskForum/aff/32.aspx
dB=20*log10(psd in engineering units per sqrt(Hz)/1.0)
The slight oddity is they have use V/sqrt(Hz) rather than V^2/Hz, but that is not uncommon, and the relationship is obvious.
I suggest you read and understand the section on engineering units and dB in this
https://www.google.com.au/url?sa=t&rct=j&q...
Cheers
Greg Locock
