Table on drafting with x,y,z cooridnates of pointscreated in modeling
Hello I need your help.
I created some points in modeling application. I want to make a table on the drawing where the x,y,z coordinates are shown in this table associative. In modeling application I enter a name (not the feature name!) to this points.
I can edit the table with excel and enter there =Point("name") and then prssing shift+str+enter.
It works, but only when I use modeling and drafting in one dataset. If i use master modeling concept it does not work...
Maybe someone know why?
Thanks for your help
RE: Table on drafting with x,y,z cooridnates of pointscreated in modeling
Also, you used the word "dataset"; are you using Teamcenter?
It works for me in native NX 9.
www.nxjournaling.com
