NX JOURNAL TO AUTOMATE PART UPDATION BY READING THRU' SPREADSHEET VALUES
Could you please help me out to get thru' this.
I'm having a part file in which all the features are driven by 2 expressed variables (X & Y). These 2 variables are linked from the external spreadsheet thru' "ug_cell_read" function. This spreadsheet is having range of values (thousands of rows) for these 2 variables.
I would like to have a journal to automate the updation of the model by applying the range of values one by one for X & Y to see the part is updating without any errors, as inputting values one by one manually is taking lot of time.
Here is my requirement,
1. Feeding values for X & Y from external spreadsheet one by one within the range I'm specifying, to update the part.
2. In case, for a particular value the part is not able to update the feature(s), I would like the journal to either highlight the respective row(s) or leaving an error message against those values in the spreadsheet.
Please let me know if something is unclear or a sample file would explain the scenario much better.
Your help in this would be highly appreciated.
NOTE: Using NX7.5 and MS office 2010. Soon upgrading to NX 9.0 hopefully from 1st week of May.
mdhanush
RE: NX JOURNAL TO AUTOMATE PART UPDATION BY READING THRU' SPREADSHEET VALUES
The journal below will update the formula of an expression that uses the "ug_cell_read" or "ug_excel_read" function. It will loop through the given cells attempting to update the model. If any update errors occur, it will write the corresponding Cell address to the listing window. This code does not use the Excel file directly, it only updates an expression that makes use of a spreadsheet function.
Change the values of the constants defined near the beginning of the journal code to meet your requirements. To extend this code, you could turn it into a function or subroutine and pass in the desired range of cells as parameters to the function/sub.
CODE
'spreadsheet_update
'NXJournaling.com
'April 13, 2015
'Update a model from a range of values in a spreadsheet.
'The specified expression in the part file must make use of the
'ug_cell_read or ug_excel_read function.
'The journal will loop through the specified rows in the specified column
'and attempt to update the model.
'If any update error occurs, the corresponding cell reference is written to the listing window.
Option Strict Off
Imports System
Imports System.Text.RegularExpressions
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim theUfSession As UFSession = UFSession.GetUFSession()
        If IsNothing(theSession.Parts.BaseWork) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Const undoMarkName As String = "update expression from spreadsheet"
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
        'Change the values of the following constants to suit your needs
        '  specify spreadsheet column
        Const spreadsheetColumn As String = "A"
        '  specify spreadsheet rows
        Const spreadsheetRowStart As Integer = 1
        Const spreadsheetRowEnd As Integer = 5
        '  specify expression name in .prt file that references
        '  spreadsheet value
        Const expressionName As String = "length"
        Dim cellRef As String = spreadsheetColumn & spreadsheetRowStart.ToString
        Dim theExpression As Expression
        Try
            theExpression = workPart.Expressions.FindObject(expressionName)
        Catch ex As NXException
            If ex.ErrorCode = 3520016 Then
                'no expression found with given name
                lw.WriteLine("expression '" & expressionName & "' not found, journal exiting")
                Return
            Else
                lw.WriteLine(ex.ErrorCode & ": " & ex.Message)
            End If
        End Try
        If (theExpression.RightHandSide.ToUpper.Contains("UG_CELL_READ")) Or _
            (theExpression.RightHandSide.ToUpper.Contains("UG_EXCEL_READ")) Then
            'expression references a spreadsheet
        Else
            'cannot update cell
            lw.WriteLine("expression does not reference a spreadsheet cell, journal exiting")
            Return
        End If
        Dim strRegex As String = "(.*?ug_(?:cell|excel)_read\s*\(\s*(?<sheet>"".*?"")\s*,\s*"")(?<cell>.*?)(""\s*\)(.*))"
        Dim regexOptions As RegexOptions = regexOptions.IgnoreCase Or regexOptions.Multiline
        For i As Integer = spreadsheetRowStart To spreadsheetRowEnd
            cellRef = spreadsheetColumn & i.ToString
            Dim theMatches As MatchCollection = Regex.Matches(theExpression.RightHandSide, strRegex, regexOptions)
            Dim newFormula As String = theMatches(0).Groups(1).Value & cellRef & theMatches(0).Groups(2).Value
            theSession.UpdateManager.ClearErrorList()
            Dim markId2 As Session.UndoMarkId
            markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Expression edit")
            theExpression.RightHandSide = newFormula
            Dim nErrs1 As Integer
            Try
                nErrs1 = theSession.UpdateManager.DoUpdate(markId2)
                lw.WriteLine("** Update Error with value in cell: " & cellRef)
                lw.WriteLine("** " & ex.ErrorCode & ": " & ex.Message)
                lw.WriteLine("")
            End Try
        Next
        lw.Close()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
www.nxjournaling.com
My example only deals with one parameter, it will need to be extended to work with a second one.
However, the error message is puzzling; the line of code in the error message does not match what is posted above. It seems to have deleted part of the regular expression, specifically the angle brackets and the text within them. Perhaps the copy & paste operation "cleaned" them because it thought they were HTML? I'm not sure. Anyway, make sure that the code in your file matches what is posted above.
Below is code that works with your example file (2 parameters).
CODE
'spreadsheet_update
'NXJournaling.com
'April 14, 2015
'update: refactor code into subs/functions
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module2
    Sub Main()
            Return
        End If
        lw.Open()
        Const spreadsheetRowStart As Integer = 2
        Const spreadsheetRowEnd As Integer = 10
            Try
                UpdateExpressionRef("X", "A", i)
                    lw.WriteLine("expression 'X' not found, journal exiting")
                    Return
                Else
                End If
            End Try
            Try
                UpdateExpressionRef("Y", "B", i)
                    lw.WriteLine("expression 'Y' not found, journal exiting")
                    Return
                Else
                End If
            End Try
            Try
                DoUpdate()
                lw.WriteLine("** Update Error with value in row: " & i.ToString)
                lw.WriteLine("")
            End Try
        Next
        lw.Close()
    End Sub
    Sub UpdateExpressionRef(ByVal expressionName As String, ByVal excelColRef As String, ByVal excelRowRef As Long)
        Dim cellRef As String = excelColRef & excelRowRef.ToString
        Try
            Throw ex
        End Try
            'lw.WriteLine("expression references a spreadsheet cell")
            'lw.WriteLine(theExpression.RightHandSide)
        Else
            'cannot update cell
            Return
        End If
        'lw.WriteLine("matches found: " & theMatches.Count.ToString)
    End Sub
    Sub DoUpdate()
        markId2 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Model update")
        Try
            Throw ex
        End Try
    End Sub
    End Function
End Module
Cowski, You are the Genius. I really impressed with your journals
Thanks!
Glad to help.
