vessel re-rate
vessel re-rate
vessel re-rate
I want to re-rate a vessel which is designed for 1.5 MPag @ 190degC. This vessel has another design criteria which is 50kPag @200degC which has been ignored during the design. to re-rate it, Should I only check the design for 50kPag@ 200degC or I need to rerate the vessel for 1.5MPag @ 190degC.
basically should I consider the highest pressure @highest temperature for vessel re-rating or only checking the vessel design for missing operating condition will suffice?
Thanks.
RE: vessel re-rate
The best approach is to evaluate highest design pressure at maximum design temperature.
RE: vessel re-rate
I find it difficult to believe that 10C difference at 190C will make much of a difference unless someone really got it too tight or that most processes can be controlled that accurately.
If it passes 1.5 @ 200C, then 50kpa @ 200C should be OK.
You really need to understand where this data comes from and how much spare has been added from max operating to design temps.
RE: vessel re-rate
Thanks for your responses. If it was in design phase I would have design it to 1.5MPag @ 200degC in the first place but it is too late now. I personally think 1.5MPag @200degC is the best practice however wanted to know that checking the design for 50kPag@ 200deg would be sufficient as well or not. in other word is it a code requirement to design it to highest pressure at highest temperature? from you answers I undestarnd that it is enough to check the design for 50kPag @ 200degC.
RE: vessel re-rate
Those are strange values for different design conditions. Is the 50kPa external pressure?
I have had to re-rate piping with a sliding scale of pressure based on monitoring UT thicknesses, but that wasn't at original design.
Perhaps it came from the PSV sizing? What service is this vessel in?
