Dimension to features unseen
I'm not sure how to phrase this question but can you dimension to parts not visible in an assembly?
I think this might be covered by Y14.5M 1.4 (g)
See attached drawing and dimensions marked with red circle.
http://files.engineering.com/getfile.aspx?folder=5...
RE: Dimension to features unseen
I'd say it's OK so long as it's obvious what is meant. In a complex busy drawing it may not work, in a simple one probably fine.
If you mean is it OK to dimension to hidden detail, then no per your reference.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Hidden lines are normally only added when they help clarify a view. It is not normal practice to dimension to a hidden line. If you need to dimension to a feature that is obscured in the view, you can break out the local surface obscuring the feature.
Just for clarification I was not referring to hidden lines. I understand not to dimension to hidden lines. We use cut outs or other views when needing to refer to a hidden line.
The 8 x 1 3/8 dimension would refer to all 8 gussets from the point of view of each gusset. Because the gusset is located at the center of the each support I felt it would be self explanatory.
The relevant clause in ASME Y14.5-2009 is 1.4 (g), which states:
That is a "should" statement that implies it's poor practice to dimension to hidden lines. In your drawing, the dimensions in question are shown in true profile views and actually do refer to visible outlines...you were second-guessing yourself because they also apply to additional features that you can see in the dimensioned view. There's nothing wrong with this so long as you provide enough views to make it very clear where these dimensions apply (your top and side views do that, and your isometric drawing makes it clear even for people that don't know how to read drawings).
This is clearly not the same as dimensioning to hidden lines, and I think other people brought that up as a way of prompting you to realize that you had conflated these two concepts (just my opinion).
