Welding 16Mo3 / P11 or P22
At the drum level measurement we have a DN25 connection available, the material of that piping is 16Mo3 EN10216-2 1.5415. We want to install another level measuremnet systems. For this purpose we have to weld some pipes to this connection. The only material available we have is P11/T11 13CrMo4-5 & P22/T22 10CrMo9-10. Is It possible to weld this material with some procedure to the 16Mo3 materials.
I attached a excel table for comparison of materials:
http://files.engineering.com/getfile.aspx?folder=d...
Adolfo
Adolfo
RE: Welding 16Mo3 / P11 or P22
I have antother question. Is it specified in ASME IX, or other document, the procedures for welding to materials with diffrent P-No. if it is possible.
As far as a welding procedure specification (WPS), you will need to qualify a procedure and this will be based on information obtained from your internet search. My suggestion is to also discuss your project with someone in your organization or outside who is knowledgeable about welding ferrous materials.
